jon_iz
Jan 19, 2015Tutor
RN104 crashed and stuck at "booting" or "Updating"[FW 6.2.2]
ReadyNAS RN104 – 5 months old, so now out of 90 day warranty 2x 3TB Seagate ST3000VN000 in XRAID2 mode. Though the 90 day phone/chat support has expired, there is an email support ticket (# 24562661...
jon_iz
Feb 04, 2015Tutor
My solution, rather than using USB-SATA was to use a motherboard with enough SATA inputs... Installation Suse 64 is pretty quick, and natively supports BTRFS, so if it can read the arrays it will and might be a quicker solution to see if you can recover the data...
I wasted time first go with an old Dell precision P450, which had 2x 32bit Xeons in it - and only saw the disk as 807GB.. I guess some thing to do with 2^32 addressing.... So if you try this route, make sure you have 64bit architecture.
PS- good luck with the support call!
