ViktorN's avatar
ViktorN
Tutor
Aug 22, 2017
RN104: Defrag freezes NAS
Readynas 104, 4 × WD red (2TB each, 100 % conditioon, S.M.A.R.T. is OK), latest firmware 6.8.0, about  only 16 % of capacity is loaded.
Freezes after running defrag. The same problem in older versions as well.
Button doesn't work, display is black, just leds of disks are flashing and I can hear that disks are working (maybe with defrag routine). Web page of Readynas doesn't work, ping doesn't answer.
LOG is free of any error:
Tue Aug 22 2017 19:45:56 System: Set locale to en-us.
Tue Aug 22 2017 19:45:32 System: ReadyNASOS background service started.
Tue Aug 22 2017 19:45:07 Volume: Resyncing started for Volume data.
Tue Aug 22 2017 19:45:03 System: ReadyNASOS service or process was restarted.
Tue Aug 22 2017 15:44:29 System: Antivirus scanner definition file was updated to 58.23696.
Tue Aug 22 2017 13:19:53
Volume: Defragmentation started for volume data.
Tue Aug 22 2017 0:00:13 Snapshot: Snapshot c_1503352811 was successfully created for share or LUN Záloha.
Mon Aug 21 2017 16:24:22 System: ReadyNASOS background service started.
  • StephenB's avatar
    DId you check the disk health (disk_info.log and smart_history.log)?
    • ViktorN's avatar
      ViktorN
      Tutor
      yes, did you read the first line of my post? "2TB each, 100 % condition, S.M.A.R.T. is OK"
      • StephenB's avatar
        "OK" is to some degree subjective.  If you are seeing any pending sectors, reallocated sectors, or uncorrectable errors you might be running into issues.
        If it's not the disks, then there are a couple of other causes
        -the file system itself might have some corruption
        -the file system might not have enough free space
        -the system might be running low on memory.
        Perhaps try a scrub, and then a balance.  You could also try turning off the volume quota, and perhaps AntiVirus.
ProSupport for Business
