Spanfan
Jul 10, 2018Tutor
RN104 Degraded after upgrade to 6.9.3
I've just done a firmware update to 6.9.3 on my ReadyNas 104. Before the upgrade the Staus was shown as Healthy but after the upgrade it is shown as Degraded. The Data shows 3.34Tb free of 10.90Tb wh...
- Jul 11, 2018
Hi Spanfan,
You will still be able to use the NAS with the 3 drives in. Once you you have the new drive plug it in on bay 4 and the NAS should automatically rebuild the RAID.
Hopefully you can get a good backup of your data for protection.
Regards
Spanfan
Jul 10, 2018Tutor
Hi marc,
Three of the discs are coloured blue the fourth is grey (slot 4x1)
Hovering over the grey one shows an ATA error 41160 all the blue ones have ATA error 0
Apart from that the data is the same for all drives
Thanks
Spanfan
Spanfan
Jul 10, 2018Tutor
Forgot to say, log file sent to the email address in your link
