Spanfan
Jul 10, 2018Tutor
RN104 Degraded after upgrade to 6.9.3
I've just done a firmware update to 6.9.3 on my ReadyNas 104. Before the upgrade the Staus was shown as Healthy but after the upgrade it is shown as Degraded. The Data shows 3.34Tb free of 10.90Tb wh...
- Jul 11, 2018
Hi Spanfan,
You will still be able to use the NAS with the 3 drives in. Once you you have the new drive plug it in on bay 4 and the NAS should automatically rebuild the RAID.
Hopefully you can get a good backup of your data for protection.
Regards
Marc_V
Jul 10, 2018NETGEAR Employee Retired
Hi Spanfan
It might be dead but if it is still runnning might as well run a test. Yes the degraded status is normal. Please note that another failure will result to losing your data, so it would be better if you rebuild the RAID by replacing the bad drive.
It would be best to do a full backup since you have access to your data.
Regards
Spanfan
Jul 10, 2018Tutor
Thanks for all the help.
I've ordered a new drive. Is it ok to continue to use the Nas with just the 3 good drives until the new one arrives? Once I p0lug a new drive in will it sort itself out or do I ahve to do anything?
Unfortunately i don't have enough other storage space to do a backup of the data
- Marc_VJul 11, 2018NETGEAR Employee Retired
Hi Spanfan,
Regards
- SpanfanJul 13, 2018Tutor
New disk just installed, NAS in the prcess of Recovering Data.
Thanks for the help
The message in the display window on the NAS says Recover Data 8.41%. It's been running since this morning and slowly increasing the percentage
The Admin Page says
The ReadyNAS is currently synching. During this process, the system is still accessible, however, performance and Admin Page responsiveness might be impacted
Status: Degraded, Volume resynching
