Spanfan
Jul 10, 2018Tutor
RN104 Degraded after upgrade to 6.9.3
I've just done a firmware update to 6.9.3 on my ReadyNas 104. Before the upgrade the Staus was shown as Healthy but after the upgrade it is shown as Degraded. The Data shows 3.34Tb free of 10.90Tb wh...
- Jul 11, 2018
Hi Spanfan,
You will still be able to use the NAS with the 3 drives in. Once you you have the new drive plug it in on bay 4 and the NAS should automatically rebuild the RAID.
Hopefully you can get a good backup of your data for protection.
Regards
Spanfan
Jul 10, 2018Tutor
Thanks for all the help.
I've ordered a new drive. Is it ok to continue to use the Nas with just the 3 good drives until the new one arrives? Once I p0lug a new drive in will it sort itself out or do I ahve to do anything?
Unfortunately i don't have enough other storage space to do a backup of the data
Marc_V
Jul 11, 2018NETGEAR Employee Retired
Hi Spanfan,
Regards
