polofson
Sep 23, 2016Aspirant
RN104 firmware 6.5.2 gmail setup
Can not get this to work .. getting frustrated. gmail side enable less secure apps testmail fails regardless /peo
Sep 23, 2016Guru - Experienced User
Did you also disable two-factor authentication on the gmail side?
polofson
2 step verification is off
- StephenBSep 23, 2016Guru - Experienced User
Interesting. That does work for me. My NAS is set to port 465, use TLS is checked, and the SMTP server is set to smtp.googlemail.com
If you are using a static IP address on the NAS, double-check your subnet mask and your DNS servers. It is possible that you simply can't reach the internet from the NAS.
