Learning2NAS
Nov 23, 2015Tutor
RN104 Freezes when doing large transfers via USB 3.0 on 6.4.0
My RN10400 has been working great since purchase. However, I've never transferred over USB extensively; all of the data was loaded over the network. Now I have a large set of folders on a USB 3.0 HDD...
- Nov 24, 2015
Hello,@Learning2NAS
In my case (erratic freezezs when writing large files on disk).
An upgrade to 6.4.1 RC1 + Factory reset (AKA factory reset under 6.4.1) solved the issue.
As a test I did went back from 6.4.1 to 6.4.0 stable (what a joke ;-) ) and it immediatly froze again.
So if you are up to wipe your NAS, try a factroy reset to 6.4.1 before trying to downgrade.
Please report the result of this, it would help a lot other contributors
mdgm-ntgr
Nov 23, 2015NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
guigui_bebert
Nov 24, 2015Guide
Hello,@Learning2NAS
- Learning2NASNov 24, 2015Tutor
Thank you both for getting back to me so quickly.
I've been fooling with this thing for about ten hours and I located my issue. As I said, I'm already on 6.4.1RC and I performed a full factory reset. My unit still froze, though. Based on your answer I knew the issue had to be something else, so I went back to the drawing board.
Last week I added a clunky old 250gb drive to my RAID 5 to pickup a few extra GB and to run that old drive to its death (I hate waste, and throwing away something that works doesn't sit well with me). The drive worked great for a week, so I thought that it would be fine eventhough it isn't on the compatability list. I have had 9 drives in my RN so far, none of which were on the list and none of which caused me any problems. This 10 year old drive did, though. I don't know that the problem is because it's similar spec to my disks that work without issue, but for some reason this disk dropped behind under heavy read/write and caused the system to hang. It passes every disk test I throw at it, in the NAS or on my PC, and manages to get all the way through the RAID sync fine. As soon as I try to do something, though, the unit locks-up.
I replaced all four disks with matching HGSTs I had laying around and moved a LOT of data to it after the RAID was built. I tried USB and wired ethernet, no problems. That old disk, or a combination of all of my old disks, killed the RN. If anyone knows how/whether this can be overcome, advice would be appreciated.
Thanks again everyone :)
- Jan 17, 2024Retired_Member
