mocoyn
Feb 15, 2015Aspirant
RN104 Lost Fronted
Hi I have the same issue (lost access Frontend and I don't have SSH enabled), that other persons in this forum...what can you do? I lost the connection do this steps: - First, I've installed t...
mdgm-ntgr
Feb 16, 2015NETGEAR Employee Retired
Seeing you are running the beta your issue is different.
You can try things like
to check the load on the system
And other commands to check the status of key services:
It could be that Plex is putting such a high load on the system or there could be something else going on.
# top
# journalctl -a | grep apache2 | tail -n 20
# journalctl -a | grep readynasd | tail -n 20
# systemctl status readynasd
# systemctl status apache2
# btrfs fi show
# df -h
# df -i
