77PALE77
Jul 05, 2023Apprentice
RN104 not accessible anymore from MacBook Pro OS Ventura 13.4.1
Hi everyone, in march 2023 I bought the new Mac Book Pro 14" M2 with OS Ventura installed. For the first month everything worked fine with my ReadyNas 104. It was reachable both from browser and as...
77PALE77
Jul 06, 2023Apprentice
Yes, IP on NAS lcd is correct.
Anyway I can access NAS from every other device on my LAN, only the Mac with Ventura is not working: it seems to be a known issue of this OS, as I found doing many Google search.
I even rebooted NAS and router but nothing changed. Think I have to wait for a Ventura update, hoping Apple fixes this bug.
Jul 07, 2023Guru - Experienced User
Not being able to ping the NAS is a more fundamental issue than the SMB access problems I've seen when I google.
How is the mac connected to your network?
Can you ping other devices on your network from the mac
- 77PALE77Jul 07, 2023Apprentice
Mac is connected via wifi, and I can ping succesfully any other device on the LAN exept NAS.
- StephenBJul 07, 2023Guru - Experienced User
Which is puzzling. ping is a very basic service, so something is off.
Are you pinging it by its IP address? Or are you using the hostname?
- 77PALE77Jul 07, 2023ApprenticeBy IP adress
