77PALE77
Jul 05, 2023Apprentice
RN104 not accessible anymore from MacBook Pro OS Ventura 13.4.1
Hi everyone, in march 2023 I bought the new Mac Book Pro 14" M2 with OS Ventura installed. For the first month everything worked fine with my ReadyNas 104. It was reachable both from browser and as...
77PALE77
Jul 08, 2023Apprentice
Some devices are connected via wifi, some via ethernet.
No changes on my LAN
The only change is that Netgear dropped remote service, ReadyCloud account have expired on 1st of july. But it was for remote access to NAS. Local access is still granted and it works, but not on Mac with Ventura. Really weird…
Jul 08, 2023Guru - Experienced User
Yes, but that wouldn't affect ping at all.
Did you every try ping on the Mac back when ReadyCloud was still running?
Is there any internet security software running on the Mac?
Also, I suggest downloading RAIDar 6.5 for MacOS and seeing if that can find the NAS from the Mac.
- 77PALE77Jul 11, 2023Apprentice
I do not have any internet security software installed on my Mac
Do not know if any setting I ignore is working in background…
RAIDar detects my NAS on the LAN…
- StephenBJul 11, 2023Guru - Experienced User
I don't own a Mac, so I can't give any more tailored advice.
But I do know that ping not working is either a result of a network configuration error, or something running on the Mac that is blocking the ping request or response.
- 77PALE77Jul 13, 2023Apprentice
Do you know how I could find out what is blocking ping?
I asked my Mac via Terminal a network IP map, and NAS IP was not there…
I even thought it could be my ORBI system not routing IP’s correctly, I restarted it but nothing changed…
Talked with Apple assistance, after an hour of call and many tries nothing… re-installed OS as their last suggestion, nothing…
- 77PALE77Jul 13, 2023ApprenticeHi, finally I found the solution.
I removed static IP for my NAS on the router
It has always been a static IP, it has always worked fine but that’s it…I decided to try this solution and it worked. Don’t know why but it worked
Thanks a lot for your patience. Hope that this discussion could be helpful to many others
