PsykoGreg
Feb 15, 2015Aspirant
RN104 (perf) MTU / Jumbo Frames not working
Hello, My readyNas (RN104) seems to be not working with MTU more 1500. Configuration: NAS: RN104 Switch: GS108T PC network card Intel Pro1000PT OS: Windows 7 64 Between 2 PC with Jumbo fr...
Feb 16, 2015Guru - Experienced User
The GS108T should be set to 9216 (the max). It includes ethernet framing overhead, but the PC and NAS software do not (so it needs to be set higher than 9000 in your example). It's safe (and easiest) to set it to the max value.
For the other devices you want to find the smallest MTU that they all support, and set the NAS and the PC to that value.
