PsykoGreg
Feb 15, 2015Aspirant
RN104 (perf) MTU / Jumbo Frames not working
Hello, My readyNas (RN104) seems to be not working with MTU more 1500. Configuration: NAS: RN104 Switch: GS108T PC network card Intel Pro1000PT OS: Windows 7 64 Between 2 PC with Jumbo fr...
Feb 17, 2015Guru - Experienced User
Well, the net is that despite the configuration settings the Jumbo frames aren't working along the path. Since you know its not the switch or the PC, that would imply a problem with the RN102.
ping -l 1472 means that the full 1500 byte MTU for ethernet is ok, but nothing else is working.
You are just using one NIC? Or is the RN104 set up for teaming?
