PsykoGreg
Feb 15, 2015Aspirant
RN104 (perf) MTU / Jumbo Frames not working
Hello, My readyNas (RN104) seems to be not working with MTU more 1500. Configuration: NAS: RN104 Switch: GS108T PC network card Intel Pro1000PT OS: Windows 7 64 Between 2 PC with Jumbo fr...
Feb 17, 2015Guru - Experienced User
That seems a bit odd. Perhaps mdgm can tell something from the logs.
PsykoGreg wrote: I have just tested in direct link and it's working with 4k MTU/Jumbo parameters.
I have use the second network interface of the nas RN104.
So I have retry with the switch and with the second network interface of the nas and... it's working also :)
Well, Jumbo frames aren't inherently faster. All they do is reduce the number of packets per second that the network card+CPU have to process. The more processing that the network card does (i.e. offloads from the CPU), the smaller the benefits. If you have a really fast network card combined with a really fast CPU you won't see any benefits at all.
PsykoGreg wrote: But the transfer rate has increased very slightly. :(
36Mo/s to 45Mo/s with 4088 MTU size and with 9k MTU size i obtain the same maximum transfer speed :(
I hoped reach the 50 or 60 Mo/sec like between 2 computer with standard MTU size!
I think really this nas has a performance problem, maybe network cards are very bad... I know the processor is light but for only files transfer it's sufficient.
