pxg
Jan 15, 2016Aspirant
RN104 power supply
Hello I have a rn104 but missing power supply. I can't copy data on new storage solution. I don't find spare part reference on Netgear documentation. Have you a corect reference for me or ...
- Apr 30, 2016Hello I use a li shin 0129b1280 12V 6.67A on my RN104. The pin 1 and 2 (positive) are on the flat size of the connector (keyed size of the connector if you prefer) The RN104 work correctly Regards.
Jan 17, 2016Guru - Experienced User
It seems very unlikely that the power input pin assignments on the NAS would depend on geography. One of the reasons for using a brick is to allow one chassis to be sold worldwide.
In any event, Netgear should provide this information. Bricks can fail, and users should be able to replace them no matter what their warranty status is.
From an earlier thread ( https://community.netgear.com/t5/Using-your-ReadyNAS/Need-a-new-power-adapter-for-rn10400-100nas/td-p/977246 ), there are apparently two Netgear part numbers used - 332-10581-01 and 332-10363-02. An internal PSU replacement for an older NAS also has the 332-10581-01 part number (which seems really crazy to me btw), so you do need to be cautious on that one.
Though I don't have the RN104, I believe that the power bricks are also labeled with CAM090121. If you search on that, you will see a few other possibilities - http://www.laptop-battery.co/black-ac-adapter/4-PIN-DIN-LI-SHIN-0219B1280-CAM090121/A20994.htm
pxg
Jan 17, 2016Aspirant
Thank you for this response. I found compatible adaptor model (12V+ on pin 1 and 2) for at least 90w. these equipement are planned for concurrent nas (synolgy or qnap) 100w and cost 40-50 euros. Cheaper is li shin 0219b1280, but only 6.67A and cost 30 euros. Regards
