XAffi
Dec 09, 2015Aspirant
RN104 "readynas btrfs insert delayed dir index+" on panel
Hi all.
After updating my RN104 (2TB,3TB,4TB,4TB)to 6.4.1 last weekend everything works fine. Today I see the messege "readynas btrfs insert delayed dir index+" on the panel and the device is not accessable any more (I believe it has nothing to do with the 6.4.1 upgrade). BAckup LED still flashing and no indication on damaged HD. Any idea what happend? According the email notifications from the system it was showing some virus warning and doing some backup (rsync)... This seems to happen suddenly. Any idea what is going on?
Not much what i can do as no access (even ssl).
Thanks.
Norbert
It could be that anti-virus is hogging the resources on your system. Some users ahve reported that after disabling anti-virus performance on 6.4.1 has returned to normal.
- mdgm-ntgrNETGEAR Employee Retired
- XAffiAspirant
Thanks.... Could you explain me what the message means?
It is a critical kernel error message useful for support when troubleshooting a problem. Assuming disabling anti-virus has resolved your problem I would think this error would have been caused by the high load on the system. On a system under extremely high load tasks will take far longer than usual triggering kernel errors.
