Jumanji2
Mar 08, 2021Aspirant
RN104 Remove inactive volumes to use the disk. Disk 1,2,3,4 after Firmware upgrade
Hi, After upgrading the firmware on my ReadyNAS 104 the Volume are being displayed as Remove inactive volumes to use the disk. Disk 1,2,3,4 this use to have a RAID configuration and has years of ...
Jumanji2
Mar 10, 2021Aspirant
StephenB contacted both John and Marc got no reply so far, I was hoping it was something quite simply to resolve this as it looks like the RAID is still there just not operational.
Mar 11, 2021Guru - Experienced User
One cause is that the disks are out of sync. You can force the RAID assembly in that situation, but there can be file system corruption as a result.
You can try prod JohnCM_S or Marc_V with a follow-up private message, or just engage paid support directly. In general you don't want the gearhead support for ReadyNAS.
