TwILeK1
May 31, 2016Aspirant
RN104 start failed after update 6.5.0
Hi I updated the RN104 Nas from 6.4.2 to 6.5.0. I started the update from readycloud website after upgraded my account The nas downloaded and installed the new firmware, but can't start. Rea...
- Jun 01, 2016
Hi
Problem solved.
I mounted some directory from externa usb device in fstab
But when booting the device first try to mount disks from NOT mounted device ... (directory not found)
So can fix readynasd to skip these user error and log out :)
Remove it -> /media/USB_HDD_5/MyData /Data/MyData rw bind
mdgm-ntgr
May 31, 2016NETGEAR Employee Retired
How full is the 4GB root volume?
# df -h
# df -i
Which apps or other packages have you installed?
Can you send in your logs (see the Sending Logs link in my sig)?
TwILeK1
Hi
root@NyulNAS:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.0G 1.8G 53% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 1.2M 248M 1% /run
tmpfs 249M 0 249M 0% /sys/fs/cgroup
tmpfs 249M 0 249M 0% /media
/dev/md124 4.6T 4.1T 469G 90% /Data
tmpfs 249M 0 249M 0% /Data/Filmek/Mese
tmpfs 249M 0 249M 0% /Data/Filmek/Dokumentum
tmpfs 249M 0 249M 0% /Data/Filmek/_3D
tmpfs 249M 0 249M 0% /Data/Filmek/Western
/dev/md124 4.6T 4.1T 469G 90% /home
/dev/md124 4.6T 4.1T 469G 90% /apps
root@NyulNAS:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 63201 471 62730 1% /dev
/dev/md0 65536 36418 29118 56% /
tmpfs 63641 1 63640 1% /dev/shm
tmpfs 63641 597 63044 1% /run
tmpfs 63641 9 63632 1% /sys/fs/cgroup
tmpfs 63641 7 63634 1% /media
/dev/md124 0 0 0 - /Data
tmpfs 63641 7 63634 1% /Data/Filmek/Mese
tmpfs 63641 7 63634 1% /Data/Filmek/Dokumentum
tmpfs 63641 7 63634 1% /Data/Filmek/_3D
tmpfs 63641 7 63634 1% /Data/Filmek/Western
/dev/md124 0 0 0 - /home
/dev/md124 0 0 0 - /apps
Apps:
mysqlr6
phpmyadminr6
smbplus
Installed packages:
dpkg-query -l -> http://www.twilek.hu/apps.dpkg.txt
The admin page don't loading, so i can't download logs, but i can tar gz the /var/log/readynasd (i sent the logs to the email address)
- mdgm-ntgrMay 31, 2016NETGEAR Employee Retired
Can you download the logs using RAIDar 6.1? If so, can you send those in?
Your data volume is very full.
There's quite a bit on the 4GB root volume as well.- TwILeK1Jun 01, 2016Aspirant
Hello
I sent the logs, donwloaded by raider6 THANKS!
Yes Data partition is highly used :D but it's only a data store, it was on 98% too :)
THANKS
- mdgm-ntgrJun 01, 2016NETGEAR Employee Retired
Well the firmware upgrade guide and tips indicates that updating the firmware when the volume is very full is not recommended.
You really should keep your volume under 80% full.
You are using a non-redundant volume configuration and one of your disks has a non-zero current pending sector count.
You probably should backup your data, do a factory default (wipes all data, settings, everything) with good disks installed and restore your data from backup.
