TwILeK1
May 31, 2016Aspirant
RN104 start failed after update 6.5.0
Hi I updated the RN104 Nas from 6.4.2 to 6.5.0. I started the update from readycloud website after upgraded my account The nas downloaded and installed the new firmware, but can't start. Rea...
- Jun 01, 2016
Hi
Problem solved.
I mounted some directory from externa usb device in fstab
But when booting the device first try to mount disks from NOT mounted device ... (directory not found)
So can fix readynasd to skip these user error and log out :)
Remove it -> /media/USB_HDD_5/MyData /Data/MyData rw bind
TwILeK1
Jun 01, 2016Aspirant
Hi
420GB free space onn /Data partition ... i think it more than enough :)
I can't save my data, more than 3.5 TB ... :(
Can i reinstall the 6.5 without loosing data? from ssh console?
or revert back only readynasd binary?
TwILeK1
Hi
Problem solved.
