someotheruser
Jun 13, 2022Aspirant
RN10400 - won't boot, now won't power... anyway to replace?
Have been naively using my RN10400 for years thinking the RAID idea was protecting my data.. bad idea. This morning i was able to see my NAS root folder but not able to open subfolders. I tried rebo...
Jun 13, 2022Guru - Experienced User
Replacement power adapters are inexensive, so you could do a risk buy of one.
You can migrate the disks to any OS-6 NAS (though you will likely need to get a used one if you go down this path).
someotheruser
Already ordered power brick replacement. Suspect a couple weeks to try that.
So OS-6 are anything with model numbers like RN200, 300, 400, etc? And Netgear doesn't sell these anymore? Will see if i can find a used one.
And I am looking at ReclaiMe s/w and buying 4 USB enclosures to see if this at least lets me recover all my data.
Anything else i should be doing?
Thanks for the speedy reply. 🙂
- StephenBJun 13, 2022Guru - Experienced User
someotheruser wrote:
So OS-6 are anything with model numbers like RN200, 300, 400, etc? 🙂
Correct.
They haven't come out and said so, but there is little-to-none inventory out there.
No, I think you are pursuing all the options.
- SandsharkJun 14, 2022Sensei
StephenB wrote:
someotheruser wrote:So OS-6 are anything with model numbers like RN200, 300, 400, etc? 🙂
Correct.
Or a legacy NAS converted to OS6. Those will be at least as fast as your 104, and many are faster. Of course, they're also a lot older. But that is making them easier to find used as well as less expensive. Note that your caddies for a 104 won't fit in a legacy unit, so don't make the mistake of buying one without caddies thinking you can move yours over.
- someotheruserJun 26, 2022Aspirant
got new power supply and the nas powers up now. no display but leds working. My guess is at some point i plugged in the power plug the wrong way and it has blown the display. that or when i put it back together after taking it apart to check the power connector wasn't broken; possibly a cable or connector to the display was not seated properly. That all being said, the nas is now visible on the network and i am able to open some folders.. but things are still very slow. Running diagnostics with RAIDar and i get:
Successfully completed diagnostics
System
Disk 1 has 40 Current Pending Sectors
Disk 1 has 40 Uncorrectable Sectors
Disk 3 has 31496 Reallocated Sectors
Disk 3 has 31496 Reallocation Events
Disk 3 has 246 Command Timeouts
Disk 3 has 33232 Current Pending Sectors
Disk 3 has 33232 Uncorrectable Sectors
Volume data is degraded
Logs
2022-06-25 20:03:37: data.mount: Directory /data to mount over is not empty, mounting anyway.
2022-06-25 20:03:21: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2My guess is one of the drives (#3) is dead. I stumbled upon a page on steps to take to diagnose; which i think may have said remove the bad drive. But will see if i can find that link again.
