edthesprinter
Sep 13, 2022Aspirant
RN10400 Boot from USB Failure After Firmware Update
Hello, I went into the admin console and saw that the firmware for my ReadyNAS 104 had a firmware update. I did the update using the console, and when it rebooted, there was an error in the LED that...
Sep 14, 2022Guru - Experienced User
edthesprinter wrote:
After trying, it recognized that it was doing a recovery, but after about 3 - 5 minutes, it gave me a message: "DEBUG: Telnet" and an IP address. When I tried to telnet to that IP address, the admin/password combination did not work. Then I tried to recover again, and it gave me a DEBUG telnet IP address of 192.168.168.168. This IP address doesn't work, in fact, it's not even in my subnet.
Anyone have any suggestions?
What happens if you remove all USB drives (including the recovery disk) and reboot the NAS?
FWIW, the 192.168.168.168 IP address is what the NAS uses when getting an address with DHCP fails. Also admin/password won't work when you are access with telnet, you need to use root with a different password.
