Zefat
Sep 18, 2015Follower
RN10400 losing data transfer posibility (ping alive)
Hello, I have a RN10400. I monitor the device to look if it is up. At a point it does give me SSL down. I can still ping the device. But are not able to logon to the web interface, als the ...
Sep 18, 2015Guru - Experienced User
Current firmware for the RN104 would be 6.2.5. Can you confirm that is what you are running?
You should consider using Netgear support for this.
