Andrew_Oz
Mar 07, 2020Aspirant
RN10400 Power supply failure - flashing green light
Hi, My power supply has failed - the green light flashes about once per second and the NAS powers up for that split second and then goes off again. I suspect it's the power supply. It has a speci...
Andrew_Oz
Mar 08, 2020Aspirant
Hi Marc,
Thanks for your reply. The green light on the adapter flashes so I'm assuming it's that which has expired. If so, is this what you mean as far as a replacement goes?
Thanks
Marc_V
Mar 08, 2020NETGEAR Employee Retired
Yes that would do, if you want to have the original, contacting Support might help. They usually allow purchase of Power Adapters provided your ReadyNAS was purchased from an Authorized reseller.
HTH
Regards
- Andrew_OzMar 08, 2020Aspirant
Hi again,
I'd rather have an authentic power adapter but I can't see how to contact support without having to pay them just to contact them. Do you know if there is there a general number or email address I can use?
Many thanks
Andrew
- Marc_VMar 09, 2020NETGEAR Employee Retired
Is your device registered to MyNETGEAR Portal? If so, can you PM me your Serial number so I can help you check the availability of the Power Adapter.
HTH
Regards
- Andrew_OzMar 09, 2020Aspirant
Thanks Marc, That would be fantastic!
It is registered and the serial number is 3EP83CER00109.
Please let me know how else I can help.
Andrew
