Andrew_Oz
Mar 07, 2020Aspirant
RN10400 Power supply failure - flashing green light
Hi, My power supply has failed - the green light flashes about once per second and the NAS powers up for that split second and then goes off again. I suspect it's the power supply. It has a speci...
Mar 13, 2020Guru - Experienced User
Sandshark wrote:
Note that I have since found information that the StarTech power adapter does not have the same pin-out as a ReadyNAS supply.
There are adapters out there that claim to be compatible with the RN104. For instance: https://www.amazon.com/PK-Power-RN10400-100NAS-RN10442D-100NAS-RN10400100NAS/dp/B06XXTBP7N
Might be simplest just to get one of those.
Andrew_Oz
Mar 18, 2020Aspirant
Hi again,
I ordered this one from AC adaptors in the UK: https://www.acadaptorsrus.co.uk/replacement-for-netgear-ite-power-supply-332-10363-02-12v-7-0a-nu90-9120700-i2/
It looks as though it should work but does nothing.
When I check the old power supply the light only flashes when it's plugged into the NAS. If it's not plugged into the NAS the green light on the power brick stays on. Maybe it's not the external power supply but maybe something in the NAS?
What do you think?
Andrew
