rmdelatorre
Jul 17, 2015Aspirant
RN202 Device Communication Error
Hi, Just bought a new RN202 for my home. I connected the power and the Ethernet cable to the wifi router, as per instructions, and I accessed https://readycloud.netgear.com/. It appeared that ...
Jul 17, 2015Guru - Experienced User
Try manually setting up the RN202. https://ipaddress will bring you to the admin web page.
RAIDar 6.0 will also find the RN202, and has a control for setup you can use.
After its set up, you can try again with readycloud.
