irix
Mar 07, 2016Aspirant
RN202 extremely slow on small files
Coming from Synology I was hoping for a better OS (I really don't need all the functions Synology offers) and a faster NAS I purchased a ReadyNAS RN202. It did very well in tests, but now I'm trying ...
Mar 07, 2016Guru - Experienced User
Did you turn off the antivirus service? There is a performance-crippling issue with it (with both 6.4.1 and 6.4.2) that Netgear is working on.
irix
As I said in my topic it was never turned on. So I have to wait for a next version (or probably reflash to an earlier version?)
- StephenBMar 07, 2016Guru - Experienced User
Sorry, I missed the AV comment in the first post.
It shouldn't be that slow. Small-file copies are always slower, but it should have completed in well under an hour.
Perhaps benchmark large-file performance with NAStester (http://www.808.dk/?code-csharp-nas-performance)
- irixMar 07, 2016Aspirant
The NASTester shows the speeds I expect, also for small (1mb is the smallest) files:
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on V: 5 times...
Iteration 1: 90,21 MB/sec
Iteration 2: 80,66 MB/sec
Iteration 3: 88,36 MB/sec
Iteration 4: 92,23 MB/sec
Iteration 5: 90,97 MB/sec
Average (W): 88,49 MB/sec
Running a 400MB file read on V: 5 times...
Iteration 1: 117,85 MB/sec
Iteration 2: 117,10 MB/sec
Iteration 3: 115,71 MB/sec
Iteration 4: 118,03 MB/sec
Iteration 5: 117,89 MB/sec
Average (R): 117,32 MB/sec
Running warmup...
Running a 1MB file write on V: 5 times...
Iteration 1: 55,55 MB/sec
Iteration 2: 55,55 MB/sec
Iteration 3: 55,55 MB/sec
Iteration 4: 58,82 MB/sec
Iteration 5: 62,50 MB/sec
Average (W): 57,59 MB/sec
Running a 1MB file read on V: 5 times...
Iteration 1: 71,42 MB/sec
Iteration 2: 71,42 MB/sec
Iteration 3: 71,42 MB/sec
Iteration 4: 66,66 MB/sec
Iteration 5: 66,66 MB/sec
Average (R): 69,52 MB/sec
Running warmup...
Running a 1MB file write on V: 40 times...
Iteration 2: 58,82 MB/sec
Iteration 3: 62,50 MB/sec
Iteration 5: 58,82 MB/sec
Iteration 6: 58,82 MB/sec
Iteration 7: 58,82 MB/sec
Iteration 8: 58,82 MB/sec
Iteration 9: 58,82 MB/sec
Iteration 10: 58,82 MB/sec
Iteration 11: 58,82 MB/sec
Iteration 12: 62,50 MB/sec
Iteration 13: 58,82 MB/sec
Iteration 14: 58,82 MB/sec
Iteration 15: 58,82 MB/sec
Iteration 16: 58,82 MB/sec
Iteration 17: 62,50 MB/sec
Iteration 18: 58,82 MB/sec
Iteration 19: 58,82 MB/sec
Iteration 20: 58,82 MB/sec
Iteration 21: 58,82 MB/sec
Iteration 22: 58,82 MB/sec
Iteration 23: 58,82 MB/sec
Iteration 24: 58,82 MB/sec
Iteration 25: 55,55 MB/sec
Iteration 26: 58,82 MB/sec
Iteration 27: 58,82 MB/sec
Iteration 28: 58,82 MB/sec
Iteration 29: 58,82 MB/sec
Iteration 30: 55,55 MB/sec
Iteration 31: 58,82 MB/sec
Iteration 32: 58,82 MB/sec
Iteration 33: 58,82 MB/sec
Iteration 34: 58,82 MB/sec
Iteration 35: 58,82 MB/sec
Iteration 36: 58,82 MB/sec
Iteration 37: 66,66 MB/sec
Iteration 38: 66,66 MB/sec
Iteration 39: 30,30 MB/sec
Iteration 40: 62,50 MB/sec
Average (W): 58,62 MB/sec
Running a 1MB file read on V: 40 times...
Iteration 1: 66,66 MB/sec
Iteration 2: 66,66 MB/sec
Iteration 5: 71,42 MB/sec
Iteration 6: 71,42 MB/sec
Iteration 7: 66,66 MB/sec
Iteration 8: 71,42 MB/sec
Iteration 9: 71,42 MB/sec
Iteration 10: 76,92 MB/sec
Iteration 11: 76,92 MB/sec
Iteration 12: 71,42 MB/sec
Iteration 13: 71,42 MB/sec
Iteration 14: 66,66 MB/sec
Iteration 15: 71,42 MB/sec
Iteration 16: 66,66 MB/sec
Iteration 17: 71,42 MB/sec
Iteration 18: 62,50 MB/sec
Iteration 19: 71,42 MB/sec
Iteration 20: 71,42 MB/sec
Iteration 21: 71,42 MB/sec
Iteration 22: 71,42 MB/sec
Iteration 23: 71,42 MB/sec
Iteration 24: 71,42 MB/sec
Iteration 25: 71,42 MB/sec
Iteration 26: 71,42 MB/sec
Iteration 27: 71,42 MB/sec
Iteration 28: 71,42 MB/sec
Iteration 29: 66,66 MB/sec
Iteration 30: 66,66 MB/sec
Iteration 31: 66,66 MB/sec
Iteration 32: 71,42 MB/sec
Iteration 33: 71,42 MB/sec
Iteration 34: 66,66 MB/sec
Iteration 35: 71,42 MB/sec
Iteration 36: 71,42 MB/sec
Iteration 37: 71,42 MB/sec
Iteration 38: 71,42 MB/sec
Iteration 39: 71,42 MB/sec
Iteration 40: 66,66 MB/sec
Average (R): 70,17 MB/sec
Running warmup...
Running a 8000MB file write on V: 5 times...
Iteration 1: 88,16 MB/sec
Iteration 2: 84,49 MB/sec
Iteration 3: 88,92 MB/sec
Iteration 4: 88,98 MB/sec
Iteration 5: 88,42 MB/sec
Average (W): 87,79 MB/sec
Running a 8000MB file read on V: 5 times...
Iteration 1: 115,19 MB/sec
Iteration 2: 110,19 MB/sec
Iteration 3: 116,30 MB/sec
Iteration 4: 116,27 MB/sec
Iteration 5: 116,40 MB/sec
Average (R): 114,87 MB/sec
------------------------------ StephenBMar 07, 2016Guru - Experienced User
Interesting, but that of course leaves us without much explanation on the speeds. Is there any way you can rule out the PC?
How are you doing the copy? Normal drag/drop?
- Mar 26, 2017Retired_Member
