Alein
May 09, 2017Aspirant
RN204 can't start
Hi, I have a problem with RN204. Something is wrong with USB, I am not soure what. but this is log. Annapurna Labs stage 2: stage2_eth3_ram_loader v1.49.9 Executing next! Annapurna Labs...
Alein
May 11, 2017Aspirant
Hi,
Well, you didn't specify how I use USB front port.
So from beginning.
I am trying start NAS, I can not. I am getting error
[Thu May 11 19:01:29.803 2017] Starting the controller
[Thu May 11 19:01:29.803 2017] USB XHCI 1.00
[Thu May 11 19:01:29.804 2017] scanning bus 0 for devices... 1 USB Device(s) found
[Thu May 11 19:01:29.929 2017] scanning usb for storage devices... 0 Storage Device(s) found
[Thu May 11 19:01:29.991 2017] ** Bad device usb 0 **
So, I am trying to reinstall OS, or factory default. But after I am in boot many, I am not able to change options, there is only factory default, but I can not push it father. However, I am able to start NAS with recovery USB connected, and then NAS is recognizing it and trying to flash.
[Thu May 11 19:03:44.313 2017] U-Boot 2013.10-alpine_db-1.49 (Jan 08 2016 - 10:41:23)
[Thu May 11 19:03:44.313 2017] 01/08/2016 ReadyNAS-200 V1.1
[Thu May 11 19:03:44.328 2017]
[Thu May 11 19:03:44.328 2017] Annapurna Labs
[Thu May 11 19:03:44.328 2017] Board: Alpine Development Board
[Thu May 11 19:03:44.344 2017] I2C: ready
[Thu May 11 19:03:44.344 2017] DRAM: 2 GiB
[Thu May 11 19:03:44.376 2017] eeprom_per_device_init: no valid information found!
[Thu May 11 19:03:44.376 2017] power_init_board: EEPROM per device information is not valid - using defaults!
[Thu May 11 19:03:44.424 2017] Board config ID: Netgear NAS RN20x
[Thu May 11 19:03:44.509 2017] dt_based_init: ETH params initialization failed!
[Thu May 11 19:03:44.524 2017] ac_adapter_plug_in = 0
[Thu May 11 19:03:44.618 2017] NAND: 128 MiB
[Thu May 11 19:03:46.376 2017] 00:01.0 - 1c36:0001 - Network controller
[Thu May 11 19:03:46.456 2017] 00:03.0 - 1c36:0001 - Network controller
[Thu May 11 19:03:46.456 2017] 00:04.0 - 1c36:0011 - Cryptographic device
[Thu May 11 19:03:46.456 2017] 00:05.0 - 1c36:0021 - Base system peripheral
[Thu May 11 19:03:46.456 2017] 00:09.0 - 1c36:0031 - Mass storage controller
[Thu May 11 19:03:46.500 2017] PCIE_0: Link up. Speed 5GT/s Width x1
[Thu May 11 19:03:46.500 2017] 01:00.0 - 1b21:0612 - Mass storage controller
[Thu May 11 19:03:46.674 2017] PCIE_1: Link up. Speed 5GT/s Width x1
[Thu May 11 19:03:46.674 2017] 02:00.0 - 1b6f:7052 - Serial bus controller
[Thu May 11 19:03:46.674 2017] In: serial
[Thu May 11 19:03:46.674 2017] Out: serial
[Thu May 11 19:03:46.674 2017] Err: serial
[Thu May 11 19:03:46.674 2017] Net: , al_eth1 [PRIME], al_eth3
[Thu May 11 19:03:46.692 2017] mn=11, hr=00, dt=00
[Thu May 11 19:03:47.892 2017] Power On!
[Thu May 11 19:03:49.113 2017] SERDES 2, p4, pma, reg[13][4:4] <= 0x00
[Thu May 11 19:03:49.113 2017] SERDES 2, p4, pma, reg[15][2:0] <= 0x02
[Thu May 11 19:03:49.128 2017] Found 1 Disks!
[Thu May 11 19:03:49.128 2017] Hit any key to stop autoboot: 0
[Thu May 11 19:03:49.238 2017] bootargs=pci=pcie_bus_perf console=ttyS0,115200 reason=normal bdtype=rn204
[Thu May 11 19:03:49.253 2017] (Re)start USB...
[Thu May 11 19:03:49.253 2017] USB0: Register 8000450 NbrPorts 8
[Thu May 11 19:03:49.253 2017] Starting the controller
[Thu May 11 19:03:49.269 2017] USB XHCI 1.00
[Thu May 11 19:03:49.269 2017] scanning bus 0 for devices... 2 USB Device(s) found
[Thu May 11 19:03:50.207 2017] scanning usb for storage devices... 1 Storage Device(s) found
[Thu May 11 19:03:50.300 2017] reading uImage-recovery
[Thu May 11 19:03:52.288 2017] 3746824 bytes read in 1991 ms (1.8 MiB/s)
[Thu May 11 19:03:52.288 2017] reading initrd-recovery.gz
[Thu May 11 19:03:53.748 2017] 2733998 bytes read in 1461 ms (1.8 MiB/s)
[Thu May 11 19:03:53.810 2017] gpio: pin 33 (gpio 33) value is 1
[Thu May 11 19:03:53.826 2017] ## Booting kernel from Legacy Image at 08000000 ...
[Thu May 11 19:03:53.826 2017] Image Name: Linux-4.1.7.alpine.1
[Thu May 11 19:03:53.826 2017] Created: 2015-09-25 18:43:37 UTC
[Thu May 11 19:03:53.843 2017] Image Type: ARM Linux Kernel Image (uncompressed)
[Thu May 11 19:03:53.843 2017] Data Size: 3746760 Bytes = 3.6 MiB
[Thu May 11 19:03:53.843 2017] Load Address: 00008000
[Thu May 11 19:03:53.843 2017] Entry Point: 00008000
[Thu May 11 19:03:53.843 2017] Verifying Checksum ... OK
[Thu May 11 19:03:54.265 2017] ## Loading init Ramdisk from Legacy Image at 08800000 ...
[Thu May 11 19:03:54.265 2017] Image Name: initramfs
[Thu May 11 19:03:54.280 2017] Created: 2016-12-21 6:08:04 UTC
[Thu May 11 19:03:54.296 2017] Image Type: ARM Linux RAMDisk Image (lzma compressed)
[Thu May 11 19:03:54.296 2017] Data Size: 2733934 Bytes = 2.6 MiB
[Thu May 11 19:03:54.296 2017] Load Address: 00000000
[Thu May 11 19:03:54.296 2017] Entry Point: 00000000
[Thu May 11 19:03:54.296 2017] Verifying Checksum ... OK
[Thu May 11 19:03:54.579 2017] ## Flattened Device Tree blob at 07000000
[Thu May 11 19:03:54.595 2017] Booting using the fdt blob at 0x7000000
[Thu May 11 19:03:54.595 2017] Loading Kernel Image ... OK
[Thu May 11 19:03:55.166 2017] reserving fdt memory region: addr=0 size=100000
[Thu May 11 19:03:55.182 2017] Loading Ramdisk to 0189d000, end 01b3876e ... OK
[Thu May 11 19:03:55.668 2017] Using Device Tree in place at 07000000, end 07008bd3
[Thu May 11 19:03:55.715 2017]
[Thu May 11 19:03:55.715 2017] Starting kernel ...
[Thu May 11 19:04:01.169 2017] pci 0002:00:00.0: can't enable device: BAR 0 [mem 0x00000000-0x00000fff] not claimed
[Thu May 11 19:04:01.169 2017] pci 0002:00:00.0: Error enabling bridge (-22), continuing
[Thu May 11 19:04:01.169 2017] pci 0002:01:00.0: can't enable device: BAR 0 [mem 0xe8000000-0xe8007fff 64bit] not claimed
[Thu May 11 19:04:02.045 2017] Start to run USB Recovery...
[Thu May 11 19:04:02.123 2017] Get systype=rn204
[Thu May 11 19:04:02.204 2017] Searching for external boot flash device...sdb
[Thu May 11 19:04:07.298 2017] UBI device number 0, total 800 LEBs (101580800 bytes, 96.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[Thu May 11 19:04:07.313 2017] Internal flash attached
[Thu May 11 19:04:07.391 2017] Searching for internal boot flash device...mtd rootfs: ubi0_0
[Thu May 11 19:04:07.813 2017] Writing internal nand flash device...Erasing 128 Kibyte @ 0 -- 0 % complete Erasing 128 Kibyte @ 20000 -- 7 % complete Erasing 128 Kibyte @ 40000 -- 14 % complete Erasing 128 Kibyte @ 60000 -- 21 % complete Erasing 128 Kibyte @ 80000 -- 28 % complete Erasing 128 Kibyte @ a0000 -- 35 % complete Erasing 128 Kibyte @ c0000 -- 42 % complete Erasing 128 Kibyte @ e0000 -- 50 % complete Erasing 128 Kibyte @ 100000 -- 57 % complete Erasing 128 Kibyte @ 120000 -- 64 % complete Erasing 128 Kibyte @ 140000 -- 71 % complete Erasing 128 Kibyte @ 160000 -- 78 % complete Erasing 128 Kibyte @ 180000 -- 85 % complete Erasing 128 Kibyte @ 1a0000 -- 92 % complete Erasing 128 Kibyte @ 1a0000 -- 100 % complete
[Thu May 11 19:04:14.140 2017] Writing data to block 0 at offset 0x0
[Thu May 11 19:04:14.140 2017] Writing data to block 1 at offset 0x20000
[Thu May 11 19:04:14.155 2017] Writing data to block 2 at offset 0x40000
[Thu May 11 19:04:14.171 2017] Writing data to block 3 at offset 0x60000
[Thu May 11 19:04:14.186 2017] Writing data to block 4 at offset 0x80000
[Thu May 11 19:04:14.218 2017] Writing data to block 5 at offset 0xa0000
[Thu May 11 19:04:14.249 2017] Writing data to block 6 at offset 0xc0000
[Thu May 11 19:04:14.264 2017] Writing data to block 7 at offset 0xe0000
[Thu May 11 19:04:14.296 2017] Writing data to block 8 at offset 0x100000
Alein
[Thu May 11 19:04:14.296 2017] done
[Thu May 11 19:04:14.311 2017] Erasing 128 Kibyte @ 0 -- 0 % complete Erasing 128 Kibyte @ 20000 -- 2 % complete Erasing 128 Kibyte @ 40000 -- 4 % complete Erasing 128 Kibyte @ 60000 -- 6 % complete Erasing 128 Kibyte @ 80000 -- 8 % complete Erasing 128 Kibyte @ a0000 -- 10 % complete Erasing 128 Kibyte @ c0000 -- 12 % complete Erasing 128 Kibyte @ e0000 -- 14 % complete Erasing 128 Kibyte @ 100000 -- 16 % complete Erasing 128 Kibyte @ 120000 -- 18 % complete Erasing 128 Kibyte @ 140000 -- 20 % complete Erasing 128 Kibyte @ 160000 -- 22 % complete Erasing 128 Kibyte @ 180000 -- 25 % complete Erasing 128 Kibyte @ 1a0000 -- 27 % complete Erasing 128 Kibyte @ 1c0000 -- 29 % complete Erasing 128 Kibyte @ 1e0000 -- 31 % complete Erasing 128 Kibyte @ 200000 -- 33 % complete Erasing 128 Kibyte @ 220000 -- 35 % complete Erasing 128 Kibyte @ 240000 -- 37 % complete Erasing 128 Kibyte @ 260000 -- 39 % complete Erasing 128 Kibyte @ 280000 -- 41 % complete Erasing 128 Kibyte @ 2a0000 -- 43 % complete Erasing 128 Kibyte @ 2c0000 -- 45 % complete Erasing 128 Kibyte @ 2e0000 -- 47 % complete Erasing 128 Kibyte @ 300000 -- 50 % complete Erasing 128 Kibyte @ 320000 -- 52 % complete Erasing 128 Kibyte @ 340000 -- 54 % complete Erasing 128 Kibyte @ 360000 -- 56 % complete Erasing 128 Kibyte @ 380000 -- 58 % complete Erasing 128 Kibyte @ 3a0000 -- 60 % complete Erasing 128 Kibyte @ 3c0000 -- 62 % complete Erasing 128 Kibyte @ 3e0000 -- 64 % complete Erasing 128 Kibyte @ 400000 -- 66 % complete Erasing 128 Kibyte @ 420000 -- 68 % complete Erasing 128 Kibyte @ 440000 -- 70 % complete Erasing 128 Kibyte @ 460000 -- 72 % complete Erasing 128 Kibyte @ 480000 -- 75 % complete Erasing 128 Kibyte @ 4a0000 -- 77 % complete Erasing 128 Kibyte @ 4c0000 -- 79 % complete Erasing 128 Kibyte @ 4e0000 -- 81 % complete Erasing 128 Kibyte @ 500000 -- 83 % complete Erasing 128 Kibyte @ 520000 -- 85 % complete Erasing 128 Kibyte @ 540000 -- 87 % complete Erasing 128 Kibyte @ 560000 -- 89 % complete Erasing 128 Kibyte @ 580000 -- 91 % complete Erasing 128 Kibyte @ 5a0000 -- 93 % complete Erasing 128 Kibyte @ 5c0000 -- 95 % complete Erasing 128 Kibyte @ 5e0000 -- 97 % complete Erasing 128 Kibyte @ 5e0000 -- 100 % complete
[Thu May 11 19:04:14.498 2017] Writing data to block 0 at offset 0x0
[Thu May 11 19:04:14.514 2017] Writing data to block 1 at offset 0x20000
[Thu May 11 19:04:14.514 2017] Writing data to block 2 at offset 0x40000
[Thu May 11 19:04:14.514 2017] Writing data to block 3 at offset 0x60000
[Thu May 11 19:04:14.514 2017] Writing data to block 4 at offset 0x80000
[Thu May 11 19:04:14.530 2017] Writing data to block 5 at offset 0xa0000
[Thu May 11 19:04:14.530 2017] Writing data to block 6 at offset 0xc0000
[Thu May 11 19:04:14.561 2017] Writing data to block 7 at offset 0xe0000
[Thu May 11 19:04:14.576 2017] Writing data to block 8 at offset 0x100000
[Thu May 11 19:04:14.608 2017] Writing data to block 9 at offset 0x120000
[Thu May 11 19:04:14.639 2017] Writing data to block 10 at offset 0x140000
[Thu May 11 19:04:14.654 2017] Writing data to block 11 at offset 0x160000
[Thu May 11 19:04:14.686 2017] Writing data to block 12 at offset 0x180000
[Thu May 11 19:04:14.717 2017] Writing data to block 13 at offset 0x1a0000
[Thu May 11 19:04:14.732 2017] Writing data to block 14 at offset 0x1c0000
[Thu May 11 19:04:14.764 2017] Writing data to block 15 at offset 0x1e0000
[Thu May 11 19:04:14.779 2017] Writing data to block 16 at offset 0x200000
[Thu May 11 19:04:14.810 2017] Writing data to block 17 at offset 0x220000
[Thu May 11 19:04:14.842 2017] Writing data to block 18 at offset 0x240000
[Thu May 11 19:04:14.857 2017] Writing data to block 19 at offset 0x260000
[Thu May 11 19:04:14.888 2017] Writing data to block 20 at offset 0x280000
[Thu May 11 19:04:14.920 2017] Writing data to block 21 at offset 0x2a0000
[Thu May 11 19:04:14.935 2017] Writing data to block 22 at offset 0x2c0000
[Thu May 11 19:04:14.966 2017] Writing data to block 23 at offset 0x2e0000
[Thu May 11 19:04:14.998 2017] Writing data to block 24 at offset 0x300000
[Thu May 11 19:04:15.013 2017] Writing data to block 25 at offset 0x320000
[Thu May 11 19:04:15.044 2017] Writing data to block 26 at offset 0x340000
[Thu May 11 19:04:15.076 2017] Writing data to block 27 at offset 0x360000
[Thu May 11 19:04:15.091 2017] Erasing 128 Kibyte @ 0 -- 0 % complete Erasing 128 Kibyte @ 20000 -- 3 % complete Erasing 128 Kibyte @ 40000 -- 6 % complete Erasing 128 Kibyte @ 60000 -- 9 % complete Erasing 128 Kibyte @ 80000 -- 12 % complete Erasing 128 Kibyte @ a0000 -- 15 % complete Erasing 128 Kibyte @ c0000 -- 18 % complete Erasing 128 Kibyte @ e0000 -- 21 % complete Erasing 128 Kibyte @ 100000 -- 25 % complete Erasing 128 Kibyte @ 120000 -- 28 % complete Erasing 128 Kibyte @ 140000 -- 31 % complete Erasing 128 Kibyte @ 160000 -- 34 % complete Erasing 128 Kibyte @ 180000 -- 37 % complete Erasing 128 Kibyte @ 1a0000 -- 40 % complete Erasing 128 Kibyte @ 1c0000 -- 43 % complete Erasing 128 Kibyte @ 1e0000 -- 46 % complete Erasing 128 Kibyte @ 200000 -- 50 % complete Erasing 128 Kibyte @ 220000 -- 53 % complete Erasing 128 Kibyte @ 240000 -- 56 % complete Erasing 128 Kibyte @ 260000 -- 59 % complete Erasing 128 Kibyte @ 280000 -- 62 % complete Erasing 128 Kibyte @ 2a0000 -- 65 % complete Erasing 128 Kibyte @ 2c0000 -- 68 % complete Erasing 128 Kibyte @ 2e0000 -- 71 % complete Erasing 128 Kibyte @ 300000 -- 75 % complete Erasing 128 Kibyte @ 320000 -- 78 % complete Erasing 128 Kibyte @ 340000 -- 81 % complete Erasing 128 Kibyte @ 360000 -- 84 % complete Erasing 128 Kibyte @ 380000 -- 87 % complete Erasing 128 Kibyte @ 3a0000 -- 90 % complete Erasing 128 Kibyte @ 3c0000 -- 93 % complete Erasing 128 Kibyte @ 3e0000 -- 96 % complete Erasing 128 Kibyte @ 3e0000 -- 100 % complete
[Thu May 11 19:04:15.232 2017] Writing data to block 0 at offset 0x0
[Thu May 11 19:04:15.232 2017] Writing data to block 1 at offset 0x20000
[Thu May 11 19:04:15.232 2017] Writing data to block 2 at offset 0x40000
[Thu May 11 19:04:15.247 2017] Writing data to block 3 at offset 0x60000
[Thu May 11 19:04:15.247 2017] Writing data to block 4 at offset 0x80000
[Thu May 11 19:04:15.263 2017] Writing data to block 5 at offset 0xa0000
[Thu May 11 19:04:15.294 2017] Writing data to block 6 at offset 0xc0000
[Thu May 11 19:04:15.325 2017] Writing data to block 7 at offset 0xe0000
[Thu May 11 19:04:15.341 2017] Writing data to block 8 at offset 0x100000
[Thu May 11 19:04:15.372 2017] Writing data to block 9 at offset 0x120000
[Thu May 11 19:04:15.403 2017] Writing data to block 10 at offset 0x140000
[Thu May 11 19:04:15.419 2017] Writing data to block 11 at offset 0x160000
[Thu May 11 19:04:15.450 2017] Writing data to block 12 at offset 0x180000
[Thu May 11 19:04:15.481 2017] Writing data to block 13 at offset 0x1a0000
[Thu May 11 19:04:15.497 2017] Writing data to block 14 at offset 0x1c0000
[Thu May 11 19:04:15.528 2017] Writing data to block 15 at offset 0x1e0000
[Thu May 11 19:04:15.559 2017] Writing data to block 16 at offset 0x200000
[Thu May 11 19:04:15.575 2017] Writing data to block 17 at offset 0x220000
[Thu May 11 19:04:15.606 2017] Writing data to block 18 at offset 0x240000
[Thu May 11 19:04:15.637 2017] Writing data to block 19 at offset 0x260000
[Thu May 11 19:04:15.653 2017] Writing data to block 20 at offset 0x280000
[Thu May 11 19:04:15.686 2017] Writing data to block 21 at offset 0x2a0000
[Thu May 11 19:04:15.701 2017] Writing data to block 22 at offset 0x2c0000
[Thu May 11 19:04:15.733 2017] Writing data to block 23 at offset 0x2e0000
[Thu May 11 19:04:15.764 2017] Writing data to block 24 at offset 0x300000
[Thu May 11 19:04:15.779 2017] Writing data to block 25 at offset 0x320000
[Thu May 11 19:04:27.457 2017] done
[Thu May 11 19:04:27.661 2017] reboot: Power down
After start, whole problem is starting from beginning.
I was trying to remove USB recovery during boot, and I was able to get some command line, but without success doing something usefully.
I also was able to stop boot, and get some env variables.
All logs I will send you on priv, as there is serial number.
- StephenBMay 11, 2017Guru - Experienced User
https://kb.netgear.com/21543/How-do-I-send-all-logs-to-ReadyNAS-Community-moderators
