jplee3
May 09, 2024Apprentice
RN204 Eminent fan failure?
Hi all, I'm getting this notice in /var/log/messages on my ReadyNAS RN204: "Setting EDA fan 15 failed - deferring" I tried switching fan modes and saw this after switching to Quiet mode: "S...
- May 12, 2024
That sounds like an error in the OS. While a NAS that can use an EDA2000 or EDA4000 can set the fan speed in them, there is no similar capability on an EDA500. I retired my EDA500 and other eSATA expansions some time ago, and that error must have come into play sometime after I did so.
jplee3
May 10, 2024Apprentice
So I'm pretty sure the Mediasonic box being connected to the RN204 is what is causing the "Setting EDA fan 15 failed" message to pop-up.
I powered everything off and only powered the RN204 back up. Checked kern.log and the message didn't appear at all for the entire time I had the unit up without the Mediasonic connected (this was probably a period of 10-15 minutes or so). These "Setting EDA fan" messages would pop-up every couple of minutes btw.
I powered the Mediasonic back on and rebooted everything and now the message is back up.
So it seems there's some process within readynasd on the RN that is attemping to send a fan control setting message to what it *thinks* is the EDA and it's obviously failing since it's not actually an EDA that's connected.
Sandshark
May 12, 2024Sensei
- jplee3May 13, 2024Apprentice
Yea, maybe they changed something... in either case, the error is still propogating. I wish there was a way to silence it but I don't think there will be a very easy solution to this, especially now that these units are EOL
