KMikhail
Nov 25, 2016Aspirant
RN204 hangs since 6.5.2
Good day, My RN204 came with 6.5.0 and after installing 4x 6TB Red's, setting up RAID6 with encryption and checking I have successfully updated it to 6.5.1. Ever since it had no issues whatsoever...
- Dec 04, 2016
Just to let community and developers know - scrub (48+ hrs) finishes and no hanging up anymore happens after the beta firmware was installed.
Great work!
Nov 25, 2016Guru - Experienced User
If the scrub is in process, I'd let it finish and then try the beta. (In other words, don't pull the plug unless the unit is hung).
KMikhail
Thanks for the quick response. I can't really tell if the scub is in progress, since the panel is off, and there is no way I can access the box via LAN (discovery tool doesn't do it either).
I guess I will let it go for about as long as my regular scub goes.
Thanks,
Mikhail
- StephenBNov 25, 2016Guru - Experienced User
If you know the IP Address (or can see it in the router admin screens), maybe trying pinging it.
- KMikhailNov 25, 2016Aspirant
Hi, thanks again.
Request timed out.
I've pulled the plug. As usual, nothing in the log. Upon rebooting the box got a new IP address.
I'm updating the firmware.
Thanks,
Mikhail
