KMikhail
Nov 25, 2016Aspirant
RN204 hangs since 6.5.2
Good day, My RN204 came with 6.5.0 and after installing 4x 6TB Red's, setting up RAID6 with encryption and checking I have successfully updated it to 6.5.1. Ever since it had no issues whatsoever...
- Dec 04, 2016
Just to let community and developers know - scrub (48+ hrs) finishes and no hanging up anymore happens after the beta firmware was installed.
Great work!
KMikhail
Thanks for the quick response. I can't really tell if the scub is in progress, since the panel is off, and there is no way I can access the box via LAN (discovery tool doesn't do it either).
I guess I will let it go for about as long as my regular scub goes.
Thanks,
Mikhail
Nov 25, 2016Guru - Experienced User
If you know the IP Address (or can see it in the router admin screens), maybe trying pinging it.
- KMikhailNov 25, 2016Aspirant
Hi, thanks again.
Request timed out.
I've pulled the plug. As usual, nothing in the log. Upon rebooting the box got a new IP address.
I'm updating the firmware.
Thanks,
Mikhail
