KMikhail
Nov 25, 2016Aspirant
RN204 hangs since 6.5.2
Good day, My RN204 came with 6.5.0 and after installing 4x 6TB Red's, setting up RAID6 with encryption and checking I have successfully updated it to 6.5.1. Ever since it had no issues whatsoever...
- Dec 04, 2016
Just to let community and developers know - scrub (48+ hrs) finishes and no hanging up anymore happens after the beta firmware was installed.
Great work!
KMikhail
Dec 04, 2016Aspirant
Great work!
FramerV
Dec 04, 2016NETGEAR Employee Retired
Hi KMikhail,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
