phaze's avatar
phaze
RN204, "Read-only file system", no error messages anywhere
The NAS has been running fine for a long time, with 4 x 6TB WD Reds in RAID5, single volume.   light usage scenario, mainly as Acronis backup destination for around 10 users. No apps installed. Ou...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 23, 2018
    Quotas aren't the issue in this case.
    However I do see errors in the logs (e.g. in systemd-journal.log) about the filesystem being forced to read-only.
    If the NAS is used for primary storage of important data I'd backup that data and verify that it's good, then do a factory default (wipes all data, settings, everything) and restore data from backup.
ProSupport for Business
