phaze
Mar 22, 2018Aspirant
RN204, "Read-only file system", no error messages anywhere
The NAS has been running fine for a long time, with 4 x 6TB WD Reds in RAID5, single volume. light usage scenario, mainly as Acronis backup destination for around 10 users. No apps installed. Ou...
- Mar 23, 2018
Quotas aren't the issue in this case.
However I do see errors in the logs (e.g. in systemd-journal.log) about the filesystem being forced to read-only.
If the NAS is used for primary storage of important data I'd backup that data and verify that it's good, then do a factory default (wipes all data, settings, everything) and restore data from backup.
mdgm-ntgr
Mar 23, 2018NETGEAR Employee Retired
Do you have lots of snapshots? Are quotas enabled on your data volume (note having this enabled at the volume level is necessary to support showing space usage for each share and a total for snapshots in the GUI, so quotas may be enabled on your data volume even if you haven't set any quotas on shares).
Can you provide your logs (see the Sending Logs link in my sig)?
phaze
Mar 23, 2018Aspirant
Hi,
Logs sent, thanks.
Snapshots are disabled on all shares, and a quota is set for only one share.
Everything on the webGUI, all settings and reported info, seem to be correct and normal.
Thanks again for your help.
Lorenzo
- phazeMar 23, 2018Aspirant
Hi, sorry, yes: quotas is set to on at the volume level...
- mdgm-ntgrMar 23, 2018NETGEAR Employee Retired
I was hopeing there was a way out of resetting everything, but not a big deal.... just a pain to setup all the shares again.
Do you think I could use a configuration backuip file, once I factory reset the unit?
Thanks for your time in helping me resolve the issue.
Best regards.
Lorenzo
