phaze
Mar 22, 2018Aspirant
RN204, "Read-only file system", no error messages anywhere
The NAS has been running fine for a long time, with 4 x 6TB WD Reds in RAID5, single volume. light usage scenario, mainly as Acronis backup destination for around 10 users. No apps installed. Ou...
- Mar 23, 2018
Quotas aren't the issue in this case.
However I do see errors in the logs (e.g. in systemd-journal.log) about the filesystem being forced to read-only.
If the NAS is used for primary storage of important data I'd backup that data and verify that it's good, then do a factory default (wipes all data, settings, everything) and restore data from backup.
phaze
Mar 23, 2018Aspirant
Hi, sorry, yes: quotas is set to on at the volume level...
mdgm-ntgr
Mar 23, 2018NETGEAR Employee Retired
- phazeMar 23, 2018Aspirant
I was hopeing there was a way out of resetting everything, but not a big deal.... just a pain to setup all the shares again.
Do you think I could use a configuration backuip file, once I factory reset the unit?
Thanks for your time in helping me resolve the issue.
Best regards.
Lorenzo
- mdgm-ntgrMar 23, 2018NETGEAR Employee Retired
phaze wrote:Do you think I could use a configuration backuip file, once I factory reset the unit?
Yes. In any case if you have a problem with restoring a config backup you could always do another factory reset and manually reconfigure.
So it's a good idea to take some screenshots of the configuration just in case.
OK, good idea.
Cheers.
Lorenzo
