anothernas
Feb 10, 2014Aspirant
RN2100 - Dead drives, replaced but still showing 'Dead'
I have a ReadyNAS 2100 with 2 dead drives. I purchased identical replacement drives and smashed them back in. With the 2 new drives, they still show up 'Dead'. I powered the ReadyNAS down (i know i mi...
vandermerwe
Feb 10, 2014Master
Should.
You should perhaps test the remaining 2 older drives using vendor tools.
You may want to factory default with only 1 drive in initially, just to make sure there isn't some other hardware problem. If it's successful then power down, add all disks and factory default again.
4.2.26 is out, I see you are on 4.2.25.
viewtopic.php?f=51&t=75176
