U_V
Sep 05, 2017Aspirant
RN212 ftps issues after 6.8.0 firmware update
Hello to everybody listening. After upgrading to 6.8.0 firmware cannot browse to directories when connecting with ftps. Used winscp and filezilla, same results with AndFtp android app. It looks like...
- Jan 25, 2018
Hi U_V
Is the NAS integrated to an AD?
Can you use leapFTP or CoreFTP to check if it still has the same issue.
You can also try to upgrade to BETA 1 6.9.3 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-3-T211-Beta-1/m-p/1493242
Hope this helps!
kohdee
Sep 07, 2017Administrator
That's very interesting. I was not able to reproduce on my RN524X on 6.8.0, but I didn't do an upgrade from an existing version.
What version were you on before?
In 6.8, the only thing we modified with FTP in the name is around allowing you to use a custom port in the hostname field on backup jobs, and it was failing validation, so not sure your issue was directly related to 6.8.
