U_V
Sep 05, 2017Aspirant
RN212 ftps issues after 6.8.0 firmware update
Hello to everybody listening. After upgrading to 6.8.0 firmware cannot browse to directories when connecting with ftps. Used winscp and filezilla, same results with AndFtp android app. It looks like...
- Jan 25, 2018
Hi U_V
Is the NAS integrated to an AD?
Can you use leapFTP or CoreFTP to check if it still has the same issue.
You can also try to upgrade to BETA 1 6.9.3 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-3-T211-Beta-1/m-p/1493242
Hope this helps!
U_V
Sep 12, 2017Aspirant
Hello Marty_M.
This is the link for the logs:
<redacted>
FYI I was using the last firmware before 6.8.0
Thanks
Sep 12, 2017Guru - Experienced User
Please resend your link and password privately. You can do that by email - see this link: https://kb.netgear.com/21543/How-do-I-send-all-logs-to-ReadyNAS-Community-moderators
