U_V
Sep 06, 2017Aspirant
RN212 ftps issues after 6.8.0 firmware update
Hello to everybody listening. After upgrading to 6.8.0 firmware cannot browse to directories when connecting with ftps. Used winscp and filezilla, same results with AndFtp android app. It looks like...
- Jan 25, 2018
Hi U_V
Is the NAS integrated to an AD?
Can you use leapFTP or CoreFTP to check if it still has the same issue.
You can also try to upgrade to BETA 1 6.9.3 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-3-T211-Beta-1/m-p/1493242
Hope this helps!
Marty_M
Sep 20, 2017NETGEAR Employee Retired
U_V,
I have not receive the link where I can download the logs. One of our Netgear Expert Kohdee did respond to the thread and have an inquiry I would recommend to answer the inquiry since it may give additional information on what might have cause the behavior of the NAS.
Marty_M
NETGEAR Community Team
