U_V
Sep 05, 2017Aspirant
RN212 ftps issues after 6.8.0 firmware update
Hello to everybody listening. After upgrading to 6.8.0 firmware cannot browse to directories when connecting with ftps. Used winscp and filezilla, same results with AndFtp android app. It looks like...
- Jan 25, 2018
Hi U_V
Is the NAS integrated to an AD?
Can you use leapFTP or CoreFTP to check if it still has the same issue.
You can also try to upgrade to BETA 1 6.9.3 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-3-T211-Beta-1/m-p/1493242
Hope this helps!
U_V
Jan 18, 2018Aspirant
Hello again. Unfortunately not even firmware 6.9.1 solved the problem I mentioned. I can't undestand why for some people I read about in other posts, ftp problems solved after firmware 6.9.0 and mine still persists.
Marc_V
Jan 25, 2018NETGEAR Employee Retired
Hi U_V
Hope this helps!
