RichardB56's avatar
RichardB56
Apprentice
Apr 01, 2025
RN212 Need to Reinstall OS Often
My RN212 runs ok for a month or 2 and then I either cannot access the admin page or my backups fail to connect.  If I reinstall the OS it seems to fix the issue but I seem to have to do this about every other month.  Is this a sign the unit is failing?
  • This issue is still an annoyance.  Everytime I shutdown I have to do a OS reinstall to get to the admin page.  The data is still accessible but any backup to the RN212 fails unless I do the OS reinstall.  The power to the EPROM after power down seems to be lost.
    • StephenB's avatar
      Are you able to reach the admin page using the NAS IP address?  Or does that also fail?
      • RichardB56's avatar
        RichardB56
        Apprentice
        I cannot reach the admin page by IP address or RAIDar.  After a shutdown, controlled or not, I have to OS reinstall to be able to access the admin page.  The drives are accessible in Windows Explorer but no Admin page.
  • Doubtful it's a hardware issue.  How full is your OS partition?  Are you getting warnings about it in your log?
    • StephenB's avatar
      RichardB56:
      1. Also, what apps (if any) do you have installed on the NAS?
      2. What firmware are you running?
        RichardB56
        Apprentice
        NAS firmware 6.10.10
        I cannot access the admin page now.  I cannot see the log file.
        I do not know the OS partition or where to find it.
        I do not have any apps running or installed.
        I'll have to do a OS reinstall, again.
ProSupport for Business
