vishw
Aug 14, 2026Follower
RN21200 how can i reset password without data loss.
hi i have RN21200 how can i reset password without data loss.
Aug 14, 2026Guru - Experienced User
vishw wrote:i have RN21200 how can i reset password without data loss.
See page 51 in the manual for information on the OS reinstall (which will among other things reset the admin password back to password):
It also will
- set the network configuration to DHCP with no bonding.
- disable volume quota (which can be re-enabled from the volume settings wheel).
