cheesedoodle's avatar
cheesedoodle
Follower
Aug 29, 2017
RN21200 Researching connecting ReadNAS to Samsung SmartTV
RN21200 Researching connecting ReadNAS to Samsung SmartTV without going through my wireless network. I'm assuming i'll have to set up a separate "server", hub and such. I do have an unused Raspberry ...
  • Newsat11's avatar
    Sep 08, 2017
    You won't need a separate server. Enable DLNA access on the folders you want to share with the television. Make sure the devices are connected to the same network and check the manual of your Samsung device for information on what file formats are supported through your version of AllShare (DLNA).
ProSupport for Business
