Mangopie
May 07, 2021Follower
RN214 best way to request file from 3rd party?
Hi, I'm looking for a way to send a request to another person and have them upload a file onto my server. Basically, if another person takes a photo of my kid, I want to send them a link where they c...
May 07, 2021Guru - Experienced User
You can sort-of do this with ReadyCloud, but I think installing NextCloud would be better. NextCloud has a "anonymous upload" feature that is substantially the same as what you are wanting. https://docs.nextcloud.com/server/stable/user_manual/en/files/file_drop.html
You can get a package for NextCloud that will work on your RN214 from https://rnxtras.com/readynas-os6-arm. There is a small cost (€2.99), but you do get support for installation and configuration if you need it.
Another way to get there is to use cloud storage (Dropbox, Google Drive, or OneDrive) for the upload, and sync the cloud storage to a share on the NAS with the built-on cloud apps.
