aeldaly
Mar 06, 2019Follower
RN214 btrfs corruption forced readonly
I'm getting BTRFS corruption...
So it started with turning on teaming for the NIC cards in network settings. The device locked up and I had to force restart it. When it did, it started a rebala...
Mar 07, 2019Guru - Experienced User
I'd start by booting it up read-only (if it's not read-only already) and making a backup of the files.
Hopchen
Mar 07, 2019Prodigy
Yes, try rebooting into read only mode. You might be able to access the data then and take a backup if you don't have one already.
Do you have a recent log-set? I can take a quick look at it if you like. You can make a Google link or something similar and PM me that.
Cheers
