Starminder
Apr 26, 2019Guide
RN214 Cannot connect
Raidar sees it, but I cannot connect to the admin page through a web browser, connection refused. Apparently pool is offline. I've had a case open for almost a week now with little response :/. Ca...
Hopchen
Apr 27, 2019Prodigy
I can also take a look at those logs for you.
Upload the log zip file to Google drive or similar. Share it and PM me the link to download them.
Cheers
- HopchenApr 27, 2019Prodigy
Hi again
Thanks for sending logs over.
Something odd is going on with the raids here. I think you were running a raid0 on 3 disks (Volume: "Pool")?
Did you try to replace a disk at some point? Or did you try and add a disk?
Let me know a little more about your setup. Cheers
- StarminderApr 28, 2019Guide
Yes, the current setup is raid0 with three 8TB disks and the Volume name is Pool. I noticed Plex was offline and rebooted, now the volume is ofline and I cannot connect to the admin interface. Like I mentioned, Raidar dies see it, but I'm stuck in this half pregnant state. Is there way to get to a safe mode from here? Thanks for looking, I need all the help I can get.
- StarminderApr 30, 2019Guide
I have booted into tech support mode....still stuck, appreciate thoughts on what comes next.
