Starminder
Apr 26, 2019Guide
RN214 Cannot connect
Raidar sees it, but I cannot connect to the admin page through a web browser, connection refused. Apparently pool is offline. I've had a case open for almost a week now with little response :/. Ca...
Hopchen
Apr 27, 2019Prodigy
I can also take a look at those logs for you.
Upload the log zip file to Google drive or similar. Share it and PM me the link to download them.
Cheers
Hopchen
Apr 27, 2019Prodigy
Hi again
Thanks for sending logs over.
Something odd is going on with the raids here. I think you were running a raid0 on 3 disks (Volume: "Pool")?
Did you try to replace a disk at some point? Or did you try and add a disk?
Let me know a little more about your setup. Cheers
- StarminderApr 28, 2019Guide
Yes, the current setup is raid0 with three 8TB disks and the Volume name is Pool. I noticed Plex was offline and rebooted, now the volume is ofline and I cannot connect to the admin interface. Like I mentioned, Raidar dies see it, but I'm stuck in this half pregnant state. Is there way to get to a safe mode from here? Thanks for looking, I need all the help I can get.
- StarminderApr 30, 2019Guide
I have booted into tech support mode....still stuck, appreciate thoughts on what comes next.
- StarminderMay 01, 2019Guide
Still stuck. Anyone? Bueller?
