Starminder
Apr 26, 2019Guide
RN214 Cannot connect
Raidar sees it, but I cannot connect to the admin page through a web browser, connection refused. Apparently pool is offline. I've had a case open for almost a week now with little response :/. Ca...
Hopchen
Apr 27, 2019Prodigy
Hi again
Thanks for sending logs over.
Something odd is going on with the raids here. I think you were running a raid0 on 3 disks (Volume: "Pool")?
Did you try to replace a disk at some point? Or did you try and add a disk?
Let me know a little more about your setup. Cheers
Starminder
Apr 28, 2019Guide
Yes, the current setup is raid0 with three 8TB disks and the Volume name is Pool. I noticed Plex was offline and rebooted, now the volume is ofline and I cannot connect to the admin interface. Like I mentioned, Raidar dies see it, but I'm stuck in this half pregnant state. Is there way to get to a safe mode from here? Thanks for looking, I need all the help I can get.
- StarminderApr 30, 2019Guide
I have booted into tech support mode....still stuck, appreciate thoughts on what comes next.
- StarminderMay 01, 2019Guide
Still stuck. Anyone? Bueller?
- StephenBMay 01, 2019Guru - Experienced User
It'd be best to wait for Hopchen or JohnCM_S since they've seen your logs.
My next step would be mount the OS partition and chroot. You do that by entering
# rnutil chroot
Were you able to access the NAS shares with SMB before you booted into tech support mode?
