hdoverobinson
Nov 29, 2016Tutor
RN214 Disk Failure Message but Healthy SMART Data
Hello, After an unrelated power incident yesterday, my RN214 was shut down ungracefully. After the outage, it resynced the array and functioned normally for a few hours. Early this morning, it wa...
Nov 29, 2016Guru - Experienced User
I'd let it finish, and then schedule a disk test.
hdoverobinson
Dec 02, 2016Tutor
Thanks Stephen! When the rebuild finished, I ran a disk test. It came back clean and all three drives are now showing as healthy again. It added the "failed" drive back into the array. I'm running a volume scrub now to make sure it's all cleaned up. I'm still concerned that it flagged the drive as failed in the first place and spent all this time rebuilding. Is this expected behavior for ReadyNAS, or could it be a bug? I'm on 6.6.0.
- StephenBDec 03, 2016Guru - Experienced User
It's not expected behavior, which I guess makes it either a bug or some hardware glitch.
