freakout
Mar 09, 2024Star
RN214 internal power supply failure
Hi all, My second ReadyNAS (RN214) died recently after five years of always-on use. Same thing that killed my previous one - failure of the internal power supply. I've had some awful problems...
- Mar 10, 2024
Recovery is now in progress, humming along the LAN to my new QNAP at a blistering 75MB/s, ish. Not sure if that speed limit is due to the resources I allocated to the VM (bridged adapter, 2 CPUs, and 2GB of RAM) or some other limitation happening on the network. But whatever, at least it's working! The VM recognized the raw drives instantly and booted just like real hardware would. Even reverted to my old login credentials.
Sandshark, I have 4 x 8TB Seagate Ironwolf Pros in RAID 5, for 20TB available space. I'd offer a minor tweak to the instructions that you posted:
1) Firstly, Windows users may encounter problems getting vboxmanage.exe to actually mount the raw drives, getting an ACCESS ERROR message (or something like that), as I did at first. This is likely due to a permissions problem with VboxSVC.exe - go into the Properties menu and set it to run as administrator. Run vboxmanage.exe and VirtualBox itself as admin, too. Once I did this it all worked smoothly.
2) Second, the createrawvmdk command has now been deprecated and VirtualBox recommends you don't use it. The new approved method for mounting a raw drive is:
VBoxManage.exe createmedium disk --filename nas1.vmdk --format=VMDK --variant RawDisk --property RawDrive=\\.\PHYSICALDRIVE1
Thanks again for posting your initial guide - I likely wouldn't have my data back without it!
Sandshark
Mar 10, 2024Sensei
It does sound like the flash image may be corrupt.
I've not run it on VitrualBox >V6, so there may be an additional; setting needed if you are running V7.
Make sure the "flash" image is installed on SATA channel zero and that EFI boot is not enabled.
You should also be able to disconnect the hard drive image and see if it boots and searches for disks.
Note that booting without a drive installed will cause the OS to update to 6.10.10 unless you have the Ethernet settings set such that it cannot see the internet (like Host Only mode). While Netgear has claimed to me that this auto-update is impossible, it absolutely does happen, at least in some cases, with the VM being one of them.
- freakoutMar 10, 2024Star
Thanks Sandshark. Fortunately, a helpful YouTuber uploaded the image to Google Drive for me. There's a link in his video description here, if anyone else has this issue: https://www.youtube.com/watch?v=l1wnpyGb4cA
I've successfully booted the VM now and have access to the GUI. I'll make an attempt at connecting the drives for recovery tomorrow (it's 0100 here!). Will update this thread to help out others who may face the same problem as the ReadyNAS hardware that's still out there gets older.
- SandsharkMar 10, 2024Sensei
Glad you got it worked out.
How large are your drives? One thing I never did is try to determine if there was a limit to the drive size, just as there is a limit to the number of drives. So let us know if you have success.
