aks-2
Sep 07, 2026Apprentice
RN214 OS6.10.10 Snapshots
I found this post from 2021, but I am not seeing what I expect from snapshots. I have had this config for a long time, let's assume >2Y. I expected a monthly snapshot to be retained, as the d...
Sep 17, 2026Guru - Experienced User
aks-2 wrote:However, Sandshark mentioned defrag and snapshot don't play nicely, and I did a defrag 21-Aug - maybe this caused this round of deletions (a bit delayed however, and not all (yet)):
defrags can greatly increase the snapshot space (as Sandshark pointed out in his reply). The puzzle here is that the defrag completed quite quickly.
In any event, the auto-deletion for volume safety deletes the oldest snapshots first, and stops when the free space goes back under the threshold. So it is possible I guess.
I didn't notice that the defrag and the balance were run back-to-back. So maybe also run another balance, now that you know you have free space.
aks-2
Sep 20, 2026Apprentice
Thanks, as I posted earlier, I don't see any issue with available free space, unless I'm missing something?
I ran another balance, it completed very fast, ~10s:
[26/09/20 22:12:23 WEST] notice:volume:LOGMSG_BALANCE_STARTED_VOLUME Balance started for volume data.
[26/09/20 22:12:42 WEST] notice:volume:LOGMSG_BALANCE_COMPLETED_VOLUME Balance complete for volume data.
- StephenBSep 20, 2026Guru - Experienced User
I think there must have been an issue back when the auto-pruning was triggered. Since the volume now has plenty of free space, it must have been taken up by snapshots.
Do you have volume quota turned on? That would let you know how much space the snapshots are taking.
Speed of mine varies, the last one took about half an hour. Though I have had some that completed in ~10 seconds.
The reason I suggested re-running the balance is that I thought it might not have been able to relocate any chunks. That would perhaps explain the very fast run time.
Of course, it could also be that there was nothing that needed to be relocated. (FYI you can see the relocated chunks in volume.log).
- aks-2Sep 21, 2026Apprentice
Yes quota is enabled. Snapshop pruning is set at 90%.
I can see see this in volume web I/F:
Snapshots taking 1.17GB - currently 8.79TB / 14.54TB used (~60%) where does this info show up in the logs?
How would I be able to tell? The volume is 14.5TB, with 5.7TB free, with no significant deletions, and no addition of drives. This is the latest btrfs info:
# btrfs filesystem df /data Data, single: total=8.79TiB, used=8.79TiB System, RAID1: total=32.00MiB, used=992.00KiB Metadata, RAID1: total=1.00GiB, used=19.34MiB Metadata, DUP: total=1.00GiB, used=420.44MiB GlobalReserve, single: total=68.22MiB, used=0.00B # btrfs filesystem usage /data Overall: Device size: 14.54TiB Device allocated: 8.80TiB Device unallocated: 5.75TiB Device missing: 0.00B Used: 8.79TiB Free (estimated): 5.75TiB (min: 2.88TiB) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 68.22MiB (used: 0.00B)Thanks for looking.
- StephenBSep 21, 2026Guru - Experienced User
It would be hard to track down now, unless you have old log zips.
Note that snapshots take no space when first created - data blocks are mitrated to the snapshots only when the those blocks are no longer part of files in the main file system. Additional drives and new files do not increase snapshot size. Deletions, defrags, file updates (live databases, torrents, some backup software), and folder re-organization (since in many cases moves are really copy+delete) can all result in lots of snapshot space.
Your 14 September log snip shows at least two triggers for the pruning - 2025 June/July and 2026 April. Both show the system deleting old snapshots (more than one year back), so not the usual "thinning" (which removes snapshots at most 8 weeks old).
This appears to be the last of the triggered deletions in that snip:
[26/04/19 11:44:29 WEST] info:snapshot:LOGMSG_SMART_SNAPSHOT_DELETE_INFO Snapshot prune worker successfully deleted snapshot 2025_12_27__00_00_18 from share or LUN Shared.The 90% threshold might possibly have triggered again after that date, so I guess you could double-check that.
