Alaska_Stuart
Feb 02, 2017Tutor
RN214 Reports volume capacity at 5% after defrag
I have two RN214, one as a server and the other as a backup. The server is set up as RAID 6, the backup as X-RAID 5. Neither are approaching 10% used. However, both drives consistently report warning...
Feb 03, 2017Guru - Experienced User
I think you've discovered that defrag is triggering bad behavior in AV.
Personally I wouldn't trust the AV at the moment (though the errors posted seem to be mostly involving false positives).
Another option is to use a PC AV package that supports scanning of network shares, and use that for now. Though it will have some performance impact, since it is running over the network.
Alaska_Stuart
Feb 03, 2017Tutor
Thanks for the suggestion.
AV and defrag are definitely interacting in an undesireable way. What causes what is not within my ability to discern. I hope someone who has that ability is looking at this issue.
